RichE99
Apr 08, 2017Aspirant
N300 trek pr2000 can not get any connections at all. Need simple help to set up
Hello, I'm pretty computer and networking savvy, have set up all sorts of networks and home routers and wifi in the past with no problems. Got this Netgear Trek N300 PR2000 as a present thinking ...
- Apr 10, 2017
The unit seems to be faulty.
When you toggle the button to "Wired" then it should provide you an IP address.
In your case it doesn't and since you already reset the unit I suggest that you get it replaced.
