patrikmartin's avatar
patrikmartin
Follower
May 22, 2016
N300 Wireless Router hacked
I have a N300 wireless router of model WNR2000v4. The name of the network has been extended by "-Hacked by " followed by a Russian email address. And then this very same email address appears in the ...
  • netwrks's avatar
    May 22, 2016
    Open a web browser. Type in 192.168.1.1 You should get a login page prompt form the router.
    Login and reconfigure. If you can't login then reset to factory default and start over. Change login and password and wifi passphrase.
    Not only can you get hacked with default passwords, but people can easily connect to your wifi and use your bandwidth, or, use  for malicious / illegal activities, in which you would be held responsible.
    Router manual: http://www.downloads.netgear.com/files/GDC/WNR2000V4/WNR2000v4_UM_14Mar2014.pdf
