Reb1
Jun 26, 2016Aspirant
N600 - Can't find Access List after firmware upgrade
I just upgraded my N600 to V1.0.0.52_1.0.81 and I can no longer get to my Access List to edit/add a MAC address. There used to be a button for it at the bottom of Advaced>Advanced Setup>Wireless Sett...
- Jun 27, 2016
Hi Reb1
Welcome to the community!
What are the changes you need to do?
It's either you delete or add by clicking the dropdown arrow that says "View list of allowed devices..."
If you want to change the device name then delete it first then add it again using the desired device name.
ElaineM
Jun 27, 2016NETGEAR Employee Retired
Hi Reb1
- Reb1Jun 27, 2016Aspirant
Hi Elaine,
Thanks for the reply. I can't say I'm liking this deviation from a normal ACL. It looks like my old ACL is gone and I'm going to have to add some devices back in. It's also not very user friendly to have to delete a device if I want to change the name, as I'll have to put the MAC address back in, too. I wish I hadn't updated the firmware, and I may even consider rolling it back. But thanks for telling me how this new system works.
