tymyphotos's avatar
tymyphotos
Follower
Mar 17, 2017
N600 C3400 wndr3400v2 Wifi Speeds Slow
Unfortunately, after reading so many threads on this model, I'm not sure there is a fix.
I recently upgraded my comcast internet to Blast!. Unfortunately with this router I'm not seeing an increase in speeds via wifi. I've tried everyting I've read in the threads on this issue but still I'm not getting any speeds above 30mbps even though I'm paying for speeds 4x that much. Can anyone help me?
  • You were right. Bought an AC router and speeds are correct. Thanks.
  • I do have same issue with N600 WNDR3700 v2.
    Ofcourse my wifi is turned on , but get only 10-20mbps while on wired , I get 110+ mbps
    • ElaineM's avatar
      ElaineM
      NETGEAR Employee Retired
      opravin Just to be clear, what's the speed you're getting when you are directly connected with wired?
      What's the expected speed you paid for?
      Is the issue only on wireless connection?
      What's the wireless device? What's the wireless adapter used?
      • ralleman87's avatar
        ralleman87
        Hey ElaineM I am having the same issues. I get (and expect) 90 mbps hard wired, but I am only getting 20 mbps on wifi using xfinity sped test. I am using a 2013 macbook pro that has 802.11ac wireless networking. I have tried firmware update, factory reset, and switching channels on 2.4GHz. I am getting 20mbps on both 2.4 and 5GHz.
        Do you have any other recommendations?
        Thanks,
        Rick
