ShawnLevin
Apr 07, 2016Aspirant
N600 can't find modem
Recently, a houseguest pushed the wifi button on my N600 WNDR3700. Now the router is seemingly unable to find my modem. I'm able to log into the router both wirelessly and via ethernet cable. I'm als...
- Apr 10, 2016
Firmware update solved it, thanks team!
ElaineM
Apr 08, 2016NETGEAR Employee Retired
Hi ShawnLevin
Welcome to the community!
Since you are able to get online through the modem, you may just need to reconfigure the router in order to get back up and running.
See this article on how to configure the router to work with the modem.
- ShawnLevinApr 08, 2016Aspirant
Hi ElaineM,
Thanks for the link!
I've tried methods 1 and 2. I will attempt to update the router's Firmware manually, however why would it require a firmware update to fix when it was working fine, and the problem was caused from a user interaction?
At any rate, I'll give that a shot.
-Shawn
