ShawnLevin
Apr 07, 2016Aspirant
N600 can't find modem
Recently, a houseguest pushed the wifi button on my N600 WNDR3700. Now the router is seemingly unable to find my modem. I'm able to log into the router both wirelessly and via ethernet cable. I'm als...
- Apr 10, 2016
Firmware update solved it, thanks team!
VE6CGX
Apr 08, 2016Master
OP, what is the model of the modem? Is it a modem/router combo?
- ShawnLevinApr 08, 2016Aspirant
It's a Motorola SIRFboard SB6121, not a modem/router combo. The router is an N600 WNDR3700.
- VE6CGXApr 08, 2016Master
As mentioned earlier, I'd try reset to factory default, then set up the router again.
- ShawnLevinApr 10, 2016Aspirant
