ShawnLevin
Apr 07, 2016Aspirant
N600 can't find modem
Recently, a houseguest pushed the wifi button on my N600 WNDR3700. Now the router is seemingly unable to find my modem. I'm able to log into the router both wirelessly and via ethernet cable. I'm als...
- Apr 10, 2016
Firmware update solved it, thanks team!
VE6CGX
Apr 08, 2016Master
OP, what is the model of the modem? Is it a modem/router combo?
ShawnLevin
Apr 08, 2016Aspirant
It's a Motorola SIRFboard SB6121, not a modem/router combo. The router is an N600 WNDR3700.
- VE6CGXApr 08, 2016Master
As mentioned earlier, I'd try reset to factory default, then set up the router again.
- ShawnLevinApr 10, 2016Aspirant
- ShawnLevinApr 13, 2016Aspirant
Well, I hate to re-hash this, but I'm not sure this solution is going to be a total fix. Tonight my fiancee spilled water near the power strip for the router, and as a percaution, I unplugged it (turns out, there wasn't any water near it). When I turned everything back on, this same thing was happening. The modem could connect fine, and I could connect directly to it and browse, but via the router, the internet light was orange, and the router firmware said I had no internet connection. I was already on the latest firmware, so I couldn't update it. I was able to just update it with the same version, but this is not a reasonable solution every time I accidentally (or purposefully) power cycle my equipment.
What did my houseguest pushing the wifi button do and how I can undo it?
