AML49's avatar
AML49
N600 Port Question
Please excuse my ignorance as I ask for help regarding my new Netgear N600 router. I have 4 ports, but only 1 is lit. Is that normal?
  • > I have 3 ethernet cables plugged into the router.
    > 1 From Blu Ray Player
    > 1 From Computer
       If those devices are powered on, and the cables are good, then the
    corresponding LAN port-status LED indicators should be lit (as described
    in the User Manual).  For an unconnected LAN port, the corresponding LAN
    port-status LED indicator should be dark (as described in the User
    Manual).
    > 1 From Cable Modem
       A modem should be connected to the router's WAN/Internet port.  The
    corresponding LED indicator for that is different (as described in the
    User Manual).
    > [...] Get the User Manual. Read. Look for the LED and button
    > descriptions.
       Did you?
  • > Model: WNDR3400v3|N600 Wireless Dual Band Router
       Is that accurate?  "N600" is a speed, not a model number.  Look at
    the product label.
    > Please excuse my ignorance [...]
       Please fetch (and consult) a copy of the User Manual for your device.
    Visit http://netgear.com/support , put in your (actual) model number,
    and look for Documentation.  Get the User Manual.  Read.  Look for the
    LED and button descriptions.
    > I have 4 ports, but only 1 is lit. [...]
       Four _LAN_ ports?  To what are they connected?
    > [...] Is that normal?
       It depends.
    • AML49's avatar
      AML49
      Thank you for your reply. I originally put the model number in the headings of the message. It is WNDR3400-V3
      1 From Computer
      1 From Cable Modem
      My main question is that only Port 1 on the face of the router is lit. Should all ports be lit?
        > 1 From Computer
        Manual).
        > 1 From Cable Modem
        User Manual).
        > descriptions.
           Did you?
