Please_Help_Me
Nov 12, 2015Aspirant
N600 Router Model WNDR3700v3 not connecting to internet
My N600 Router Model WNDR3700v3 which had previously worked is no longer connecting to the Internet. The Internet port light (in-between the Power and 2.4 GHz indicators) is a slow flashing amber li...
- Nov 22, 2015
Thank you for your input. Ended up buying a replacement.
Retired_Member
Nov 12, 2015Internet.....Internet setup...select .....Use Computer MAC Address..........reboot modem and router
do this using same PC which you used without router
Same problem........ I would replace the router
Please_Help_Me
Nov 22, 2015Aspirant
