ROGUSER's avatar
ROGUSER
Follower
Mar 01, 2016
N600 Wireless Dual Band Router WNDR3400v3 Limit the broadcast to selected in house devices?
Windows 7   Can I set the router to allow access only to my computer, a separate laptop, and two smart phones.  IE, when networks are searched for from outside the house, can I prevent those search...
  • Retired_Member's avatar
    Retired_Member
    Mar 01, 2016
    No you can't. Use a strong security like WPA2 with a long passphrase.
