Matt_P's avatar
Matt_P
Tutor
Nov 25, 2016
N600 WNDR3400V1 -- change security setting from WPA to WPA2
My iPad is starting to kick me off the home WiFI network after 5-10 minutes.  When I look at the WiFi setup on that device it presents me with a security recommendation of WPA2.  So I assume this is ...
  • TheEther's avatar
    Nov 25, 2016
    Try temporarily setting it to None, Apply, then to WPA2-PSK and Apply.
