R47's avatar
R47
N900 not allowing samsung Bluray player to access
My new Samsung Blueray player can see the Wifi and i can input my security code but it won't connect. I've tried everything with samsung support and we can't get it to connect. I haven't had issues with anything else?
  • Hi R47,
    Check the security option that BluRay supports. Lower down the security option of BluRay does not support WPA2.
  • michaelkenward's avatar
    michaelkenward
    These things usually come down to the settings on the BluRay player. These "smart" devices are actually very dim. You might do better to find a forum where people talk about Samsung's BluRay players.
    I had hell's own trouble getting my Samsung BD-F6500 to work over wifi. Fortunately, I had already decided to go down the Powerline Ethernet route and now use the LAN feature.
    • R47's avatar
      R47
      Thanks for the response. I went through the aettings with the Samsung support guy. I'm thinking it's something with the router
      • JamesGL's avatar
        JamesGL
        NETGEAR Employee Retired
        Hi R47,
