Christophe56
Jul 20, 2017Aspirant
N900 (WNDR4500v2) Web Administration not accessible
Hello, Overnight, the router's Web administration server became inaccessible: the port 80 was closed, but everything else was still functioning properly (Wi-Fi, local connectivity and Internet, e...
- Jul 24, 2017
Thanks to AndyOxon I succeeded to unbrick my router!
I bought this cable (2.46€): niceeshop(TM) PL2303HX USB TTL Pour UART COM RS232 Câble Module Convertisseur (Noir, 1m)
https://www.amazon.fr/gp/product/B00F167PWE/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
And I connect it to the router like here, switching TXD and RXD:
https://www.myopenrouter.com/article/how-set-serial-console-netgear-wndr4500v2
1- nothing
2- TXD, green cable
3- nothing
4- nothing
5- RXD, white cable
6- GND, black cableI connected my laptop with the router on Ethernet port LAN1, and on USB with the PL2303HX cable.
Then, on my laptop, using Linux and picocom:
picocom -s 115200 /dev/ttyUSB0
I started by doing a normal boot and waited for a shell. Then, I kept CTRL + C on the picocom prompt and rebooted (physically) the router. A CFE prompt has appeared. I executed the following command:
CFE> nvram erase *** command status = 0
In another shell on my laptop, I connected in TFTP on the router:
tftp> connect 192.168.1.1 tftp> mode binary tftp> timeout 90 tftp> put WNDR4500v2-V1.0.0.62_1.0.39.chk
Do not hit enter after the "put" command!
Back to the CFE shell in picocom:
CFE> flash -noheader : flash1.trx
Press Enter and very quickly switch to the shell with TFTP and also press Enter to validate the "put" command.
CFE> flash -noheader : flash1.trx Reading :: Done. 12804154 bytes read Programming...done. 12804154 bytes written *** command status = 0 CFE> reboot Decompressing...done
and then... it does not work for me... yet.
This boot ends with:
Checking crc...Invalid boot block on disk [...] Start TFTP server Reading ::
Go back to the TFTP shell and execute the "put" command again. Into the picocom shell:
Reading :: Done. 12804154 bytes read Programming...done. 12804154 bytes written Decompressing...done [...]
And now it's all good! The router is fully functional using firmware 1.0.0.62_1.0.39 (and telnet backdoor is still here...).
Christophe56
Jul 23, 2017Aspirant
Thank you ElaineM. Unfortunately, the router is no longer under warranty.
I ordered a USB to RS232 cable, but in the meantime I managed to get a shell on the router.
Using the netgear backdoor described here, with the Python (UDP version) script:
https://wiki.openwrt.org/toh/netgear/telnet.console
https://github.com/insanid/netgear-telenetenable
./telnetenable.py 192.168.1.1 <routermacaddr> admin password Sent telnet enable payload to '192.168.1.1:23' root@eeepc:/# telnet 192.168.1.1 Trying 192.168.1.1... Connected to 192.168.1.1. Escape character is '^]'. BusyBox v1.7.2 (2015-06-04 17:07:24 CST) built-in shell (ash) Enter 'help' for a list of built-in commands. #
However, I can not launch the http server manually. Here are the error messages:
# httpd -E /usr/sbin/ca.pem /usr/sbin/httpsd.pem Can't find handler for ASP command: eco_get_redirect_link(); Can't find handler for ASP command: cdl_cgi_set_hijack(0); Can't find handler for ASP command: cdl_cgi_set_hijack(1); Info: No FWPT default policies. rmmod: l7_filter insmod: cannot insert '/lib/modules/2.6.22/kernel/lib/MultiSsidCntl.ko': Success (17) ioctl(BRCTL_SET_BCMCTF_ENABLE): Operation not supported ioctl(BRCTL_SET_BCMCTF_ENABLE): Operation not supported rmmod: /lib/modules/2.6.22/kernel/lib/AccessCntl.ko [AFP]: 0 partitions found. [AFP]: disk mountd:0 hfsplus mounted:0 [AFP]: no disk mounted. killall: bftpd: no process killed httpd: socket bound in 0.0.0.0:80. httpd: socket bound in 0.0.0.0:443. httpd_sig_usr:6060 buf: handle_genie: don't know how to process url
and httpd kills itself.
I think the interesting error is "httpd_sig_usr:6060" (httpd received a bad signal?)
If I put an HTTP request into /tmp/tmp_http_request.txt I can remove the handle_genie error and get a new one:
# echo "GET shares HTTP/1.0" > /tmp/tmp_http_request.txt # echo "Host: routerlogin.net" >> /tmp/tmp_http_request.txt # httpd -E /usr/sbin/ca.pem /usr/sbin/httpsd.pem Can't find handler for ASP command: eco_get_redirect_link(); Can't find handler for ASP command: cdl_cgi_set_hijack(0); Can't find handler for ASP command: cdl_cgi_set_hijack(1); Info: No FWPT default policies. rmmod: l7_filter insmod: cannot insert '/lib/modules/2.6.22/kernel/lib/MultiSsidCntl.ko': Success (17) ioctl(BRCTL_SET_BCMCTF_ENABLE): Operation not supported ioctl(BRCTL_SET_BCMCTF_ENABLE): Operation not supported rmmod: /lib/modules/2.6.22/kernel/lib/AccessCntl.ko [AFP]: 0 partitions found. [AFP]: disk mountd:0 hfsplus mounted:0 [AFP]: no disk mounted. killall: bftpd: no process killed httpd: socket bound in 0.0.0.0:80. httpd: socket bound in 0.0.0.0:443. httpd_sig_usr:6060 buf:GET shares HTTP/1.0 Host: routerlogin.net SendData3Client:763 error sending data.
But httpd is still killed...
erase nvram and reboot does not resolve the problem too.
- Does this problem talk to anyone?
- Can I flash the firmware from this console? Currently the firmware on the router is 1.0.0.60/1.0.38 and I would like to update it to 1.0.0.62/1.0.39, hoping that the update fix the problem. I am able to upload WNDR4500v2-V1.0.0.62_1.0.39.chk to the the router using wget but I don't know how to tell the router that it should apply it.
Christophe56
Jul 24, 2017Aspirant
1- nothing
2- TXD, green cable
3- nothing
4- nothing
5- RXD, white cable
6- GND, black cable
