Oosty
Mar 29, 2017Tutor
NBN HFC compatible Router
I have been upgraded to this "great" nbn internet, but I have been connected via the HFC network, sadly my isp have supplied me with a horrid, pain in the backside Gateway device (router), I prefer a...
- Mar 30, 2017
Search around here for NBN and you may find useful tips.
What is an NBN network and is my NETGEAR DSL modem router compatible? | Answer | NETGEAR Support
Some modems claim to be NBN compatible, but there are reports that this is not always the case.
You could always see if your modem can work in "modem only" mode and use it to feed a router that does the rest of the network stuff.
michaelkenward
Mar 30, 2017Guru - Experienced User
Oosty
May 10, 2017Tutor
I took the plunge and bought a Nighthawk X8, Works Great and seems to have increased the NBN speed and stabilised the connection
