NancyLee's avatar
NancyLee
Need help connecting my samsung galaxy 6 to wifi
 I have not been able to connect my phone to the wifi, I am out in the country & I have little service on my phone. I have gone through the steps to do it with no luck, tried to get help through verizon - they couldn't help. Someone please help me!!!
  • Do you see SSID of your router with Galaxy? If you do, select that SSID and connect, then you will be asked passphrase, etc.  Answer the questions, then it should connect.
    • NancyLee's avatar
      NancyLee
      Thank you for your response & help, I am now connected!
