testeri1's avatar
testeri1
Need help optimizing speed
I have a netgear cm1000 modem and a netgear xr1000.
I picked up 1200 gbps from xfinity and the router is only getting 460mbps download and 24 upload
The modem is hardwired and the modem is hardwired to the router.
Is this normal?
1 Reply
  • michaelkenward's avatar
    michaelkenward
    These are speeds measured with wired connections?
    Did you reset and reconfigure these devices for the new service?
    Is this normal?
    I don't understand. The router should be wired to the modem. It can't work otherwise.
    Just another user with time on their hands.
