dugnsarah
Jan 17, 2017Follower
Need time restrictions in parental controls
Just bought a Netgear AC1200 to replace my old Linksys Wifi router. My old router allowed me to set up time restrictions on specific devices, so that the wifi was cut off to my kids' devices late at...
- Jan 18, 2017
Hi dugnsarah,
The Parental Controls feature will allow you to set filtering level on the connected devices on the network and does not cut off the Internet connection. You can check the links below for an overview of some of the features of LPC (Live Parental Controls).
http://kb.netgear.com/app/answers/detail/a_id/25687
http://kb.netgear.com/app/answers/detail/a_id/29913
However, if you want to cut off the Internet access on the connected devices, you can use the Access Control feature either via the router's UI or through the NETGEAR Genie app. You can check the links and steps below:
http://kb.netgear.com/app/answers/detail/a_id/23289
http://kb.netgear.com/app/answers/detail/a_id/24830Via the NETGEAR Genie app:
1. Install the latest version using the link below:
http://netgear.com/home/discover/apps/genie.aspx?cid=wmt_netgear_organic
2. Open the program/app
3. Select Network Map
4. Login using the router's credentials (default: username is admin password is password)
5. Check the box "Turn On Access Control"
6. Select the device that you want to block
7. Click on "Block"
Dexter
Community Team
DexterJB
Jan 18, 2017NETGEAR Moderator
Hi dugnsarah,
7. Click on "Block"
Dexter
Community Team
