JRiv
Jul 18, 2022Follower
Net Gear AC1200 Wifi extremely slow compared to wired connection
NetGear AC1200 WIFI Cable modem Router
Model # C6220
Router is on Firmware Version V1.02.11
ISP - Xfinity
Ethernet connection speed test 89mbps
WIFI connection speed test 4.94 Mbps
My wifi speed has been extremely slow for about a week. It was running at 40-45 mbps but then it started to drop intermittently. Now it stays at the low range both 2.4 and 5 GHZ. I have the router upstairs in my office and everything was running fine until about a week ago. I usually have 5 devices connected, one wired and the rest on wifi. I have had to recycle the power several times and sometimes the wifi will speed up. The wired speed stays consistent. To eliminate possible interference, I tested my wifi on my smartphone while sitting next to the router and only reached 4.94 mbps. Sometimes it will bump up to 12mbps.
I am lost on next steps. Do a factory reset?
1 Reply
but wired you still get full speeds?
If so, you can try a factory reset and see if it helps
