mbolena's avatar
mbolena
Follower
Feb 13, 2021
Netgear AC 1750 dual band wifi mesh extender will not recognize Viasat router
Hi everyone, I had a bad reciever replaced on my Viasat dish today and a new modem along with it. My Netgear extender has worked fine for 6 months, after the maintenence work today it's no good. I downloaded nighthawk, which may have been a mistake as its of no use. Any ideas on how to get the extender to link with the modem? Any help would be appreciated!
1 Reply
  • plemans's avatar
    what model number is the new router?
    When you're installing the extender, are you using wps or using the installation assistant?
    Try using the installation assistant.
