Travis3369
Dec 31, 2017Follower
Netgear AC1200
Hi All, Can someone please help. My son has locked everyone and our devices out of our Netgear AC1200 router and blocks us all day from using the internet so he may play games without lagging. I ...
- Dec 31, 2017
> [...] our Netgear AC1200 router [...]
"AC1200" is a speed, not a model number. Ever helpful, Netgear
product packaging emphasizes speeds like "ACxxxx", but that's not the
model identifier. Look at the label.
> [...] I need to beat my son [...]
You may be right. Certainly some sort of discipline would be an
improvement over game playing.
> [...] How can I access the router, change the passwords and block him
> from all access?
Disconnect it from everything but power, and use the Reset button.
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual. Look for "factory settings"
and/or " reset ". Then connect one (your) device to it, and set a
non-default password. Then stop your son from performing the same
procedure.
antinode
Dec 31, 2017Guru
> from all access?
procedure.
- michaelkenwardJan 01, 2018Guru - Experienced User
And when you have done that, and given your router a password that your son cannot hack, look into the possibility of using parental controls. Maybe your router supports this feature.
