nginfo's avatar
nginfo
Netgear AC1750 (R6400) Has Lots of Lagging Issues
Hi All,
My Netgear AC1750 (R6400) Router has all kinds of lagging issues when streaming.  I have turned off everything that I think might interfere with data transmission.  The receiver is about 35 feet away from the transmitter and has to pas through 4-5 walls.
Is that asking too much of this router?  Does anyone have any troubleshooting ideas?  I searched the net and tried some things, but nothing has worked well.  The lagging is not consistent -- sometimes it can be really bad and other times not so bad.  There is a gamer in the house, too, so it is possible that 1 gamer and 1 streamer can be operating at the same time.
TIA...
  • plemans's avatar
    What actual speed do you get in that location from the router?
    • nginfo's avatar
      nginfo
      I took five measurements from Fast (.com?) and they were 70, 130, 110, 120, 130 Mb/s (I think my units are right, anyway).
      I just turned off 2.4 GHz and tested the router running only on 5 GHz, and it lagged and then froze for a good 30s, at which time I reset it.  A person was gaming at the same time as I took the measurements and the streaming froze.
      • plemans's avatar
        Is it only the one tv?
        What modem/gateway is the router connected to?
