giljay
Nov 08, 2022Follower
Netgear AC1750
When I plug an ethernet cord into any of the 4 ethernet connections, a steady red light comes on for that port. What does the red light mean?
usually that its connecting at 10/100mbps connection speed.
The manuals are great at going over what specific lights mean. Tough to know with yours as there's multiple models that are AC1750 as its a speed, not a model number.
There's a support site with access to manuals, firmware, install guides, etc.
Go to https://www.netgear.com/support/
Type in your model number and from there it'll take you to the above.
Its a great resource to start with. - cooper54Aspirant
Also Face This problem how to solve this.
Start by reading the previous answer.
Manuals are always a good place to start.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Check the section in the manual Troubleshoot With the LEDs.
