dorald
Sep 02, 2016Tutor
Netgear Genie - Network Map showing strange connections
Looking at the Network Map, I see way too many connections. One from Japan, several from ARRIS (?), and one from IR(?). I have tried to research these internaly but can't find them. I can account for...
- Sep 02, 2016
Doing that now. I've discovered the HON HAI connection actually my HP Printer?!?!?! Go figure. I'll keep investigating but it is beginning to look like all is OK! Guess I cried "WOLF" a little too soon. Sorry guys! I'm not very tech savy . . .as if you couldn't tell.
Thanks for the help here!
:smileyhappy:
dorald
Retired_Member
Sep 02, 2016You're Welcome,
It's scary, no doubt when that stuff shows up. Keep in mine the intruder or hack would have to be in your home or wifi range. The real concern is the ones you never see on a network map.
You might look at the router attached device list and compare them.
dorald
Sep 02, 2016Tutor
:smileyhappy:
dorald
- Retired_MemberSep 02, 2016
Does the attached device list match genie network map?
- doraldSep 02, 2016Tutor
They seem to. I'm doing a side by side comparrison now. The names don't match so having to check the MAC addresses.
I figured as much.
Thanks again,
- netwrksSep 02, 2016Master
I have a Brother printer. Wireless radio shows up as HON HAY. Have a read: http://blog.erratasec.com/2009/10/hon-hai-foxconn.html
