Mike-1
Aug 27, 2020Aspirant
NETGEAR Model R6080 Internet LED is Red? (Not described in manual)
Firmware Version: V1.0.0.42
Router has Internet LED red and everything works fine. The online PDF manual only documents Internet LED green and off, but not red.
Could you please tell me what the red LED means?
Thanks in advance,
Mike
It usually indicates an issue between the modem and the router. It could be a wire issue, a modem, issue, or potentially even a router issue.
that's why I'd start with the cable.
What modem is it connected to?
- Mike-1AspirantManufacturer: MotorolaModel: E31T2V1Provided by: SpectrumSee here for more info:https://d15yx0mnc9teae.cloudfront.net/sites/default/files/2020-08/spectrum_d3.1_emta_data_sheet_0.pdfThe real manufacturer of the modem may be Technicolor
Have you tried changing the ethernet cable between router and modem?
