krish123's avatar
krish123
NETGEAR N150 no wireless connection
i have router of netgear. now i connect my internet via ethernet cable but can't connect via wireless .so via wireless i can't connect any device .what should i do?
  • Sounds like its time to get a new router if you've exhausted all troubleshooting options with no change.
    • wcalifas831's avatar
      wcalifas831
      Prodigy
      Can you tell us the model of the router? Also you might want to power cycle it first and if that doesn't work maybe you can see if there's a firmware update for it that could help resolve the wireless connection issue. Lastly you can do a hard reset by pressing the pinhole on the back for 30 seconds but you'll have to redo the setup. Let us know what happens.
    • krish123's avatar
      krish123
      i Can do all the troubleshoot but can't do anything resoponce from router
        wcalifas831
        Prodigy
