Scoop66
May 16, 2021Follower
NETGEAR N150
I recently upgraded my computer from Windows 7 to Windows 10. I am using the Netgear N150 WNA1100 wireless adapter. I had Internet connection for a few weeks. Now I can't connect to the Internet on my desktop. The light is not flashing on the adapter. I moved to another port and still no connection. I can access the Internet on my cellphone and tablet so it does not appear to be the service provider. I have used this adapter about 6+ years.
- wcalifasProdigy
Try reinstalling the software for that adapter. Don't know about that model but there might be a windows 10 update of the software for it.
what driver are you running.
Supposedly it supports windows 10 but its an old adapter. and windows could have pushed an update that breaks compatibility. It wouldn't be the first time. It might be time to upgrade from a N150 wireless adapter
https://www.netgear.com/support/product/WNA1100.aspx#download
