LightninBob
Mar 01, 2016Aspirant
Netgear N600 WNDR3400v3 CAN'T GET MY IP PHONE TO REGISTER CISCO 504G
When connect to my router, phone will not register. My IT dept. suggested to connect phone directly to the cable modem, when I did that, the phone registered. The IT dept said the router is blocking the phone and I should turn off SIP ALG in the settings. I can't find that in the settings. Any help ??? Modem is 3 year's old.
- AnonymousMar 01, 2016
advanced ....setup.....wan setup....if the router has the option to disable it
- Anonymous
- LightninBobAspirantThank you, did what you said, found setting and disabled it. My phone registered and works perfect
