Retired_Member
Oct 27, 2022Netgear N600 WNDR3700v4 Power Adapter
I have a used Netgear N600 WNDR3700v4 router, the power adapter is missing. Where can I find the exact inner/outer diameter of the plug? Having the size I could find some generic replacement adapters...
Oct 27, 2022Guru - Experienced User
Its a 12v 1.5amp power supply according to its spec sheet.
Most of the 12v's use a pretty generic power supply setup.
You can get one with more amps (not less) but it needs to have the exact same voltage.
You might even have one sitting around from an old device.
Although for the price of a power supply, it might not be worth it on that old of a router.
