Retired_Member
Oct 27, 2022Netgear N600 WNDR3700v4 Power Adapter
I have a used Netgear N600 WNDR3700v4 router, the power adapter is missing. Where can I find the exact inner/outer diameter of the plug? Having the size I could find some generic replacement adapters...
michaelkenward
Oct 27, 2022Guru - Experienced User
thanks
Some generic adapters come with a set of tips that will fit a range of different devices.
Generic adapter
These things are pretty common, so first check to see if you have something compatible lying around.
- Retired_MemberOct 27, 2022
I'm aware of the multi-plug generic adapters, and I also already checked some of the old adapters I still have.
I would really appreciate it if further answers focus on my exact question on finding the required size of the plug.
thanks
- Retired_MemberJan 04, 2023
For the benefit of others. The power adapter must be 12v 2.5 Amp. The pin size is 5.5x2.5mm but 5.1x2.1mm also fits. Polarity: Inner: +, Outer: -
- michaelkenwardJan 04, 2023Guru - Experienced User
More than 2.5 Amps is fine.
But this bit is really good information:
Pity that Netgear makes it so hard to find.
