spike66
Dec 07, 2022Follower
Netgear Night Hawk AC1750
the 5G signal on my Netgear AC1750 suddenly became very weak. Only discoverable if I am right next to the router. Even then the signal is to weak to connect. I’ve tried the reset button and powered off the router. Can someone give me instructions how to fix the 5G signal? Thanks in advance.
1 Reply
What actual device do you have? AC1750 is a speed.
It might be the hardware failing or the firmware causing the issue.
You can try reinstalling the firmware and doing a factory reset afterward and see if it works.
If not, you can try downgrading a version in case its an issue with the version you're on.
You can also try changing what channel the 5ghz is broadcasting on.
