joaquincreixell's avatar
May 04, 2021
NetGear Orbi RBK753
Hi everyone,
Just want to make sure if the ethernet ports of the RBK753 can be used as inputs or outputs. I mean, they only come with two ports: ¿can i use them either as input or output?
Regards
  • I had also the same question with joaquincreixell about the unit Orbi RBK753's port.
    Just wanna make sure all my needed features are meet before getting one for our office.
    Thanks,
    D8 THC
  • plemans's avatar
    There isn't a "input/output" port. Lan ports are bi-directional.
    There is a wan port for internet service.
    The other lan ports can be connected however you prefer to devices/switches/etc.
