Magpie1's avatar
Magpie1
Follower
Nov 08, 2021
Netgear Powerline 1000 wifi
I am not sure what to select for location. I have the Powerline 1000 and have changed my intranet provider. I don’t believe I have an account. Could you let me know how I change the WiFi details?
  • plemans's avatar
    I'm not even sure what you're trying to do here as the description leaves a little be desired.
    If you changed providers, try factory resetting the devices (push and hold reset for 7-15 seconds while powered on).
    then simply follow the install guides for a new install.
    There's a support site with access to manuals, firmware, install guides, etc.
    Go to https://www.netgear.com/support/
    Type in your model number and from there it'll take you to the above.
    Its a great resource to start with.
  • FURRYe38's avatar
    For your future needs,
    Netgear has set up a community forum specifically for the Power Line products. Most of the people who watch that forum are more likely to have experience with these products and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
    https://community.netgear.com/t5/Powerline-Networking/bd-p/home-powerline
    Thank you.
