Ronaldoronaldo
Mar 06, 2023Aspirant
netgear r6120 wifi router and freeboox revolutionbet nas synology ds 420+ problematic 2 routers
netgear r6120 wifi router, and nas synology ds 420+
Hello Netgear Community,
My problem is the following there is an impossibility to connect to the dsm because 2 routers are detected. How can I choose just one without doing the bridge mode (or a bridge)? Could you tell me in detail the protocol to follow with the IP, local port, router port, DDNS, etc ...
If anyone can help me it will save my life. I need it for work.
A big THANK YOU in advance.
You could go freebox (in router mode)----R6120 (in AP mode)
Keep in mind the R6120 isn't a gigabit router. its ethernet ports are limited to 10/100mbps speeds so it's going to bottleneck most devices hardwired into it
This explains the logic behind the suggestion from plemans
What is Double NAT? | Answer | NETGEAR Supportand
How to fix issues with Double NAT | Answer | NETGEAR Support
