AKhozya
Mar 17, 2018Aspirant
Netgear R6220 bricked after update?
Today I've updated my router via update prompt in settings (to 1.1.0.64). After update I've got: - always lit power - blinking activity ethernet cables - wifi, internet connections are off Res...
- Mar 18, 2018
AKhozya
Mar 18, 2018Aspirant
Hmm, it's around 99% in CIS (Russia, Ukraine, Kazakhstan) of internet works like that :) They usually have box on last floor which is connected via optic channel to provider and then each flat is getting internet via ethernet cable connected to computer/laptop or WAN port of router (IP can be received via DHCP or user needs to enter IP, gateway, DNS manually on computer or router) :)
If I assign static IP to my computer connected to my router all pins fail (Request timed out)
michaelkenward
Mar 18, 2018Guru - Experienced User
Visitors from those parts are rare here. Perhaps they use their own forum.
- AKhozyaMar 18, 2018Aspirant
I'm 80% that no, these routers aren've very popular in CIS because they're quite expensive. Couldn't find any other places where I can get help. Surprisingly free support lasts only 90 days and their phone support is always busy :(
- petfyMar 18, 2018Apprentice
You can use telnet to get into the router and do stuff, like flash the firmware.
When my R6220 would not accept login credentials after a firmware update I used someones exe file to flash it by telnet.
Unfortunatly I cant find the web page for it.
- AKhozyaMar 19, 2018Aspirant
Thank you! Will try today after work :)
- AKhozyaMar 21, 2018Aspirant
That did the trick :) Thank you very much, petfy!
