bstreet's avatar
bstreet
Netgear R6350 1750ac Are Antennae detachable?
I bought 2 of these routers thinking they were the general R6400. Got home and found out they are R6350 which seem to have some features removed from the mainstream 6400. Does anyone know if these ha...
  • bstreet's avatar
    bstreet
    Jan 23, 2019
    I finally got an answer from Netgear support about the antenna. The antenna on the R6350 is NOT detachable. I wouldn't want anyone breaking the antenna trying to remove it.
    I have questions about how to proceed with my setup, but it appears I will need to open a a new thread to get answers concerning either a higher level router and/or what type of wireless extender I should get to get signal in my den.
