Andeee
Mar 27, 2019Aspirant
Netgear R6400 Can not get 5g on PC
Netgear R6400 Had the router for awhile now. We only connected at 2.4 on everything. Today we decided to look into it to see if we could connect to the 5G. All the phones hooked up to 5G with no problem the only problem is you can't hook up to the PC up to 5G. It only will hook up at 2.4. I've updated my router. Did some different troubleshooting online. I came across if I had B.G. and N That my computer will not be able to work with 5G.
There was one thing I forgot to do and that was to check the card I have in my computer. The card in my computer is not compatible with 5G. Sorry for the post My mistake.
- AndeeeAspirant
If you need the speed, and don't have a wired option, you can get an inexpensive USB adapter to add 5 GHz to a Windows PC.
