MonroeOptical
Oct 06, 2016Aspirant
NETGEAR R6400 Driver
Where is the driver for this? We recently bought an Optovue machine, and it has a Netgear R6400 in it, but it says there is no driver installed, and it cannot be found online. When I donwload it fr...
- Oct 06, 2016
MonroeOptical wrote:Where is the driver for this? We recently bought an Optovue machine, and it has a Netgear R6400 in it
An R6400 is a router. It acts as a link to bits of kit on a network, either on a wired LAN or with wifi.
NETGEAR AC1750 Smart WiFi Router Model R6400 User Manual
It isn't something that you find "in" something else.
Nor is the R6400 something that comes with "drivers" that you have to install.
If the Optovue connects to a PC, then that will probably need drivers.
What are you trying to do? Use wifi to connect a piece of equipment via the R6400?
Maybe you could explain what is going on here so that the expert can help.
real
If you bought this kit as a bundle from a supplier, they really should be the people who advise on how to get it to work.
michaelkenward
Oct 06, 2016Guru - Experienced User
real
MonroeOptical
I realize now that I don't think this piece of equipment has wifi capability without an adapter. I now installed a WLAN adapter, and it's still saying that a driver can't be found for that either! I'm going to contact the Optovue people, because really this is their issue. Thank you for your help
