JRDG3's avatar
JRDG3
Follower
Jan 21, 2018
Netgear R6400 network won't show up for certain devices
R6400/AC1750 network will show up for most devices cell phones, laptops, gaming consoles etc but when attempting to find the network while setting up devices like a RING doorbell or Amazon Alexa or wifi extender the network will not show up as available.  We have tried resetting, changing the channel to one that is 1-11 but still will not work.  Appreciate the help!
  • Hi JRDG3,
    1. What is the firmware version of the router?
    2. Can those devices detect other wireless networks within the area?
    3. Have you tried re-flashing the router firmware?
    4. When setting up those devices, are they close enough for them to detect the WiFi?
    Dexter
    Community Team
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi JRDG3,
    Dexter
    Community Team
    • DexterJB's avatar
      DexterJB
      NETGEAR Moderator
      Hi JRDG3,
      I would like to follow up and check if you are still experiencing the issue.
      Dexter
      Community Team
