BigNutBean
Apr 02, 2024Aspirant
Netgear R6400 Slow Wired Speed Issues
Good afternoon folks, I'm new to the forums and new to home networking in general. I tried searching the forums and online for solutions but I got mixed results and I'm not sure how to proceed forwar...
Apr 03, 2024Guru - Experienced User
You can check and see what link speed its connecting at
https://kb.netgear.com/24222/How-do-I-display-Internet-port-statistics-on-my-Nighthawk-router
if its 10/100mbps, then try swapping cables
BigNutBean
Apr 03, 2024Aspirant
Hello! I have checked my cables and ran them through a speed test and everything came out looking normal except when plugged into the R6400 Router as pictured below. I do not get my full speed.
_______________________________________________________________________________________________
When I ran the test as pictured below, I get my full internet speed.
I followed your instruction on checking the link speed and it shows 10/100mbps at the WAN Port. I unfortunately do not have another ethernet cable and will have to wait for another cable to arrive to test. What I don't understand is if I'm getting full speed connecting directly to the Modem, my cables should be fine and eliminated as the suspect?
Thank you!
