vctech's avatar
vctech
Netgear r6400 web interface slow
Dear Smart people,
Had Router about maybe a year, running latest firmware (V1.0.1.18_1.0.15) all of the sudden web interface slower than slow. Reboot doesn't resolve. No changes or getting creative with my config before issue started, just came out of the blue.
Any help is appreciated.
  • Hi vctech,
    1. Try using another browser.
    2. Resetting the router to factory defaults is an option.
    3. If the issue persists, you can re-flash he routers firmware then reset and reconfigure the router.
    Dexter
    Community Team
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi vctech,
    Dexter
    Community Team
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi vctech,
    I would like to follow up and check if you are still experiencing the issue.
    Dexter
    Community Team
    • vctech's avatar
      vctech
      Dexter,
      Thanks for taking the time to reply. Power cycling the router (actually removing power cable) seemed to resolve my issue, However, I will note your earlier reply and take those steps should it occur again.
      Thanks :smileyhappy:
      • DexterJB's avatar
        DexterJB
        NETGEAR Moderator
        Hi vctech,
        You are welcome. Thank you for the confirmation.
        Dexter
        Community Team
