wbramsey's avatar
wbramsey
Follower
Jun 06, 2017
Netgear Router AP mode setup (Router WNDR3800) (AP Mode Router R6050)
I have been unable to get the R6050 to work in AP Mode with the WNDR3800
My questions
1. Do I have to change any setting in the R3080?  Only changed WIFI channels to be different than AP device WiFi
2. I changed the R6050 to AP Mode.
     I'm allowing only the Router R3800 to do DHCP not the AP device R6050
     I have an ethernet cable from the AP device WAN port to the Router's lan switch
     I have an ethernet cable from an AP device lan port to a computer
          I can see that the AP device is on the network by IP scan or Router attached devices
     I have set the AP device WIFI to fixed channels different than Routers
3. How do I know if the WiFi Access Point is working?  Can I see it in attached devices or in logs?
4. Can the Router be attached to the AP device via an unmanaged switch or does it have to have a hardwired dedicated connection - Router Lan Port to AP Device WAN port?
Is there anything else I need to do to get these working together?
  • Hi wbramsey,
    1. No additional configuration is needed on your main router.
    2. It is good that the AP shows as an attached device to the main router.
    3. You can set a different SSID on the AP and connect a wireless device to it and check if it goes online. A wired device will also do.
    4. A direct connection from the router to the AP is better rather than having a switch in between.
    5. You can check the link below.
    http://kb.netgear.com/30025/
    Dexter
    Community Team
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi wbramsey,
    Dexter
    Community Team
    • DexterJB's avatar
      DexterJB
      NETGEAR Moderator
      Hi wbramsey,
      I would like to follow up and check if you are still experiencing the issue.
      Dexter
      Community Team
