GarryCR
Aug 15, 2020Follower
Netgear Router D6220 Firmware update issue
hi, I have followed Netgear instuctions to update D6220 router to latest firmware, connected to router via wifi and using Genie, downloads 1.0.0.60 ok, then router reboots ( connection reset mesage appears) , but firmware is still 1.0..0.56 ? repowered router , and still no change ? have tried 3 times no update. do i need to connected to rouer via cable ?
Thanks Garry
You should update your router while its connected via ethernet cable. Download the firmware file to your computer and then update it manually. I wouldn't ugrade the firmware to any router wirelessly since you risk bricking it if it disconnects from the wifi at some point.
Which instructions? Manual or automated?
Manual is more reliable
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
You might get more help, and find earlier questions and answers about your hardware, in the appropriate section for your device. That's probably here:
DSL Modems & Routers - wcalifasProdigy
