Illiannas
Oct 07, 2023Aspirant
NetGear Router experiencing DOS Attacks and keeps dropping WiFi
I have an old Netgear router, WNR1000v2. I've updated its firmware to V1.1.2.54, which according to it is the latest update. For a few months now, I've been experiencing my internet connections dropp...
Illiannas
Yes I know. There's supposedly still an updates page for this router along with a download update, unless that won't do anything.
I'm asking for information and help on what to do, because I haven't had issues like this until recently. If a newer router is the better option, what would be the best replacement for this one? Would newer routers be incompatible with older Windows computers? (got an older one and newer one in my household)
I'm a bit hesitant on contacting my internet provider since they don't own this router and will more often than not charge me more if they offer their own stuff.
I'm not sure why you're linking me to this tool for the DOS attacks, I already looked up the info on them and which ones are an issue. I doubt disabling the logging of the attacks would solve anything other than just keeping them out of sight and out of mind which isn't a real solution.
michaelkenward
Oct 08, 2023Guru - Experienced User
Illiannas wrote:
I'm asking for information and help on what to do....
With a router that has pretty well the slowest wifi ever made, "Up to 150 Mbps", and LAN and WAN connections limited to 100 Mbps, along with security settings from four or five generations ago, I'd say the time has come to send this router to the local recycling centre.
What does "unless that won't do anything" mean?
The release notes say what you can expect of the latest firmware update:
WNR1000v2 Firmware Version 1.1.2.60 (North America) - NETGEAR Support
Routers do not care about the age of your Windows PCs. They don't even need a PC to do their thing. Newer ones even try to push users on to mobile apps to manage routers.
As to which router to buy, it is down to what you want to do with it and your local circumstances.
Try plugging your needs into the filters on the product pages:
Wireless Routers for Home | NETGEAR
Then check back here for reports on the things you are considering, but remember that people turn up in this community with problems, not compliments. So look at reviews on Amazon, for example.
It depends on how paranoid you are and how seriously you take those reports. (They are telling you about things that the router blocked.) Most experienced users have better things to worry about. Then again, few of them rely on hardware from 2009.
That is a useful tool for anyone worried about these reports. Much better than check IP addresses one at a time.
You aren't the only one here, so we try to provide replies that means something to other people who may turn up with similar concerns.
