Shafqat's avatar
Shafqat
Netgear Router R6260 - doesnt keep my settings
Hi,
I purchased the Netgear router on ebay. Reset everything, but when I try to login to adjust settings, it does not keep my changes i.e. password or secret questions. I have tried factory reset but it still doesnt keep my settings. Any ideas?
Thanks.
  • michaelkenward's avatar
    michaelkenward
    Let's hope it wasn't sold because it was bust.
    When you say you "Reset everything", what did you actually do?
    This?
    How do I perform a factory reset on my NETGEAR router? | Answer | NETGEAR Support
    How are you working in the router? What settings are you changing? How do you know that they aren't being saved?
    • Shafqat's avatar
      Shafqat
      Factory reset.
      Added all the information to setup the router along with Admin password changes and security questions. When it was all setup, I tried to connect on my laptop using 192.168.1.1, it didnt accept the Admin details, asked for Router Serial number and then security questions which all failed.
      • plemans's avatar
        I've seen it where if you don't put in the proper requirements for the password, it makes you go back through password recovery/setup.
        Make sure to have 10 chacters
        1 special
        1 number
        1 upper case letter
        1 lower case letter.
