Sparky2wires
Aug 20, 2021Aspirant
Netgear router WGR614v9 loss of IP address on factory reset
We have a spare older style router WGR14 v9 intending to use it as a Wireless Access Point only. Router originally supplied working and configured with IP address as10.0.0.1 for safety we carried out factory reset intending to start from basics, however following the reset, router IP address remains blank when checked using PC /Run/IP Config and switching power off and rebooting.
Factory reset does not reconfigure the config file with a new temporary IP address, so remote access for router configuration changes is not possible at present.
How can we reconfigure router without any IP address.
Or can we access router another way to correct this.
Thanks Sparky2wires.
Do you have it connected to something? (another router/switch, etc)
Are you hardwiring a pc/laptop into it? Or how are you connecting a device to it?
What are all the leds on it doing? (color/blinking/solid)
when you reset, did you push and hold reset for 7-15 seconds while powered on?
- Sparky2wiresAspirant
Plemans thankyou for your quick response, my apologises for not able to respond to your post any earlier. All though I assumed router to be in working condition it has been decided the router is now considered as scrap and no further diagnosis can take place on my behalf.
I apologise to the Netgear Community for signing in and wasting your valuable time.
Regards
Sparky2wires
