hggomes
May 14, 2016Tutor
Netgear routers found to have critical vulnerabilities within the shipped software components.
I have been a Netgear tester of several router models for years now. The Netgear hardware is generally solid and reliable, however its the software side, in my opinion lacks attention in several k...
- Dec 15, 2016
Hi All,
The Security Advisory for VU 582384 has been updated.
Also, for more information and update see the thread below.
michaelkenward
Oct 28, 2016Guru - Experienced User
Ooh, you do have a bee in your bonnet don't you.
Re: Netgear Support Is expensive - NETGEAR Communities
