JLEVAVASSEUR's avatar
Sep 13, 2015
NETGEAR USB Control Center utility for MAC OS X El Capitan
NETGEAR USB Control Center utility v 2.22 is not compatible with MAC OS X El Capitan, where to download or make NETGEAR USB Control Center utility with the new MAC OS X ?
  • This is so frustrating. El Capitan has been in beta for months, and there's still no sign of a compatible NETGEAR USB Control Center utility. Now we cannot print... Where is our software Netgear?
  • ElaineM's avatar
    ElaineM
    NETGEAR Employee Retired
    Hi JLEVAVASSEUR,
    Welcome to the community!
    El Capitan is still under beta test and so is the NETGEAR USB Control Center utility.
    Rest assured that our engineering department is on top of this to make the utility work with the soon to be released OS X.
    Keep posted on our downloads page for updates.
    • fogrover's avatar
      fogrover
      Hi,
      I would like to alert you that Netgear Genie hangs on close under El Capitan 10.11.2. It also hangs under other operations.
      I hope that Netgear is working on the problem.
      Thank you.
      Fogorver
      • tuckerm2's avatar
        tuckerm2
        Any news from Netgear on this?  Surely they must be releasing an update soon?
      • ElaineM's avatar
        ElaineM
        Yes, we hear you all.
        Our engineers are working on this to get this resolved ASAP.
        I will immediately post an update once they have a fix.
        Thank you everyone for your patience.
    • Damian86's avatar
      Damian86
      Tutor
      NETGEAR USB Control Center utility v 2.22 is not compatible with El Capitan please update!
      • Brange's avatar
        Brange
        Tutor
        I can report the same problem. Is there any information when a new version of NETGEAR USB Control Center utility is available?
