jayman80's avatar
jayman80
Netgear WNDR3400V2 router wont connect to internet after a reset
So I have a netgear wndr3400v2.  I recently reset my modem, router and switch.  After the reset, the router does not connect.  Initially, I had the modem connect through the switch, then the router. ...
  • Anonymous's avatar
    Anonymous
    Oct 29, 2016
    use PC mac in router internet setup
    Or disconnect router from modem...unplug power from modem PUSH reset for 15 seconds....reconnect power to modem....wait  until modem reboots...connect router and power cycle it.
