jayman80
Oct 29, 2016Aspirant
Netgear WNDR3400V2 router wont connect to internet after a reset
So I have a netgear wndr3400v2. I recently reset my modem, router and switch. After the reset, the router does not connect. Initially, I had the modem connect through the switch, then the router. ...
- Retired_MemberOct 29, 2016
use PC mac in router internet setup
Or disconnect router from modem...unplug power from modem PUSH reset for 15 seconds....reconnect power to modem....wait until modem reboots...connect router and power cycle it.
Retired_Member
Oct 29, 2016use PC mac in router internet setup
jayman80
I have reset the router already. That did not work. What is PC MAC?
