CMitchell
Oct 19, 2016Aspirant
Netgear WNDR3700v2 wireless router
Can anyone tell me if this Netgear wireless router supports a loop back feature. If so can you tell me how to turn it on? Thanks for the help.
- Retired_MemberOct 19, 2016
Netgear Wndr3700 OEM firmware doesn't support, see if a 3rd party firmware does.
Retired_Member
Oct 19, 2016Netgear Wndr3700 OEM firmware doesn't support, see if a 3rd party firmware does.
- CMitchellOct 19, 2016Aspirant
Thanks for your help. Do you think a better solution is just to buy a new router?
